Old 27-Apr-2011, 2:06 PM   #1
Joe2011
Go or No with Winegard Hd7696P ?
TV Fool Report:
http://www.tvfool.com/?option=com_wr...8d1785476e0249
Background: I had successfully installed a LAVA HD-2805 antenna with directional motor and super low noise signal amplifier built in, on my one story ranch house on a 6 ft steel pole secured to the chimney - total height about 30 feet above ground. Un-interupted 50 foot run of coax cable to the motor controller box about 20 feet below next to the TV and then patched thru an RCA digital converter box to my Sony 2001 era analog TV - Clear 180 degree vista toward the front on the house (12:00 O'Clock) The transmitters for the weakest stations are at 3:00 O'clock. Tall trees behind and on sides of house. A big fat international airport directly between the antenna and "TV Hill" about 17 miles away in Baltimore. Channels 11 & 13 were weak ... channel 38 same transmitter location - strong?! After 9:00PM - channels 11 & 13 appeared stronger - though they did not appear to register stonger on the RCA digital converter box signal strength meter?
Per forum suggestions I replaced the Lava with a Winegard HD7694P, on the same pole, run directly to the RCA Digital converter box - no breaks, splitters or rotor controller in between. I've dialed in pointing the antenna to the compass setting from the report and even moved the direction slightly left and right for improved signal strength but the compass setting is directed through tall trees at the 3:00 O'clock position. Channels 11 now gets no signal and 13 is very bad (worse then the LAVA) The other channels are also weaker with more frequent drop outs? I've checked the connections - re-scanned several times with no improved results. I am re-installing the LAVA antenna today as I can at least get the UHF stations above 13 with some consistency while I wait for your replys. I do notice with the LAVA antenna the directional setting with the strongest signal is not in line with the report compass setting but is pointed in a sight line clearing the trees? Should I send this Winegard antenna back and seek a VHF only antenna for channels 11 & 13 with a duel antenna set up and A, B switch? Have I missed something with the highly recomended Winegard HD7694P? Are those trees the likely problem with a tight directional antenna like the Winegard?
Suggestions ... ?
Last edited by mtownsend; 27-Apr-2011 at 8:00 PM. Reason: Fixed link to TV Fool report
Joe2011 is offline   Reply With Quote
