Old 27-Apr-2011, 2:07 AM   #13
RodBarnes
@ADTech: Thanks, I'll try the FM trap and see if it makes a difference. But I find your recommendation for a 20db attenuator interesting. I would expect that to degrade the antenna's overall performance. However, having said that, I admit that when we had cable, we regularly had issues with ghosting on channel 8 -- which, I believe, indicates really strong ambient reception given it must've been leaking in through the cable connection.
GroudUrMast recommended moving the antenna outside -- which would be a fairly simple thing to do. It certainly seems that we experience increased degradation when the roof is wet -- which happens quite often around here. Do you have any recommendations on how that might improve things?
Run down to radio Shack and pick up one of these: http://www.radioshack.com/search/ind...FM%20trap&sr=1
Keep your receipt just in case.
RodBarnes is offline   Reply With Quote
