Old 26-Apr-2011, 6:53 PM   #15
Originally Posted by sdubb View Post
I still dont understand how the 10G221 works? Does it plug into the wall? I need to read up some more on that little device.
It will need power. It's a two part system. The power supply is designed to be indoors and will 'insert' power into the coax leading up to the antenna. The amplifier unit will be mounted on the mast near the antennas.
http://www.antennacraft.net/Antennas...mplifiers.html
http://www.winegard.com/offair/vhf-antennas.php
http://www.antennasdirect.com/store/...V_Antenna.html
In some cases the manufactures' web site is the best place to buy, in other cases you can find retailers with better prices.
Some of the very large all-in-one antennas approach the performance of the antennas I'm recommending but none have quite the UHF gain of the XG-91... which you will need to make reception reliable.
