Old 26-Apr-2011, 6:34 PM   #13
So does that mean even with the 2 antennas you have posted I will still lose channels 3.1 and 5.1?
I don't think so. I expect the antennas I'm suggesting will give you a very good chance at restoring the channels you lost when you moved into the shadow of the Casa Grande hills.
Virtual channel 3.1 is KTVK, real channel 24. VC 5.1 is KPHO, real channel 17. I'm reasonably confident that the added gain of the XG-91 will gather enough additional signal for you to get reception of these two stations without losing access to KNXV. I also expect this antenna to give you a good shot at restoring access to KPPX.
The H-VHF antenna will receive real channels 8,10 and 12. Channel 13 is on the back side of the antenna and may or may not be received.
