Old 25-Apr-2011, 8:27 PM   #9
Tower Guy
Originally Posted by windisch33 View Post
My antenna is pointed at 72 degrees.
You are picking up a weaker station, WWPX, that's in the wrong direction. That means that your coax should be fine and your F connectors are OK, but suggests that your antenna works in the wrong direction.
I'd double check how you figured out which is the front of the antenna and which is the side. Next, is the balun connected properly?
