Old 25-Apr-2011, 7:56 PM   #7
What are the issues if I have Cable and Antenna connected together ?
JC has already advised against any interconnection of your OTA antenna system and the CATV system. I want to back that up...
CATV systems are closed systems, which must not leak or radiate the signals. This is particularly important because CATV systems commonly use frequencies that are used for aircraft communication and navigation.
If you interconnect the CATV system with your antenna, expect a visit from the CATV company, the FCC and FAA. Have your check book ready and pack an overnight bag for your stay at a government run resort were they'll help you get your mind right. (Cool Hand Luke, 1967)
Even if you don't radiate any CATV signal, The CATV system is likely using the OTA frequencies received by your antenna. There will be mutual interference which will make the conflicting signals from both sources unwatchable. Also the OTA DTV signal format is different than the CATV DTV signal format, your tuners can typically be configured to receive one format or the other... not both at the same time.
Do I need AMP between Antenna and the splitter ?
I agree with JC. If you are having trouble with reception in the attic, it's not due to a lack of available signal power in the air. Many if not most amplifiers will be overloaded by the powerful signals at your location. Try the antenna in the attic, if it's not working reliably, move it outside into the clear.
