Tv Antennas and Reception
Always check ALL coax and connections. Look inside the coax connectors on the ends of the coax - see if the outer foil shied / shield wires are pushed in toward center conductor , the center conductor carries the signal. Being that you are at a wet climate look for corrosion. .
