rooftop vs. antenna
Hi Teleview,
Thanks so much for your reply. I've done some experimenting and feel confident that both types of antenna will work - even with reduction in reception using the attic antenna. Can you suggest any model numbers for a rooftop antenna or an attic antenna based on my signal analysis results? I'd like to get a strong enough antenna that will pick up some channels that are up to 36 miles away. Again, thanks for your reply.
LAF
