The trees putting on leaves will reduce signal strength.
The RCA ANT-751 simply does not have enough forward gain in your situation. A Winegard HD7696P or Antennacraft HBU-55 would be a more suitable choice. Higher mounting elevation may also have a significant payback... You can explore that by re-running your TVF Report at higher elevations.
If you split the signal to two or more sets, a preamplifier such as the Antennas Direst CPA19 or an Antennacraft 10G201 may be needed.
So the bottom line is, yes it's a tree problem but it's also an antenna problem.
