Old 21-Apr-2011, 8:16 PM   #1
JBS
Trees Causing Reception Problem?
I installed an RCA ANT751 on my second-floor deck this winter, facing a line of 50-60 foot trees about a hundred yards away. (I live in Iowa - no leaves on the trees in winter.) No problems, excellent reception even from towers over 50 miles away. I've attached the signal analysis results for my location.
In the last few days, I'm starting to see pixilation and break-up on 2 channels, and it's getting worse by the day. All other channels are fine. Co-incidentally (or not), the trees are just starting to leaf out.
The 2 channels with problems are 7 and 9 (real channels), the lowest of all my channels. Real channel 51 is located on the same tower as channel 9, but channel 51 reception is fine.
Does this sound like a tree problem or something else?
JBS is offline   Reply With Quote
