Old 21-Apr-2011, 6:27 PM   #5
HDOAinNC
Originally Posted by John Candle View Post
The antenna will be connected with/to a non amplified 4 way splitter. DO NOT have the Active cable Tv/cable internet and the antenna connected on the same coax cables at the same time. The coax that provides the cable tv/internet signal to the house must be disconnected at the house. For the internet connection you will need to run a separate coax.
I can isolate the INTERNET cox and connect it directly to the Active Cable TV/ Internet Cable.
And put rest of the TV's on a separate splitter with the Attic Antenna.
Do I need AMP between Antenna and the splitter ?
I already have Digital Conv. Boxes.
What are the issues if I have Cable and Antenna connected together ?
Thanks for the help so far.
HDOAinNC is offline   Reply With Quote
