Thread: Antenna Newbie
Old 20-Apr-2011, 5:58 AM   #40
dsmguy7
@groundurmast--thanks. I agree height/ position first. Then preamplifier and last bigger antenna. As far as my first tv fool report, unless I'm missing something I left the height blank. So unless it puts 20 ft in by default I don't know. Here is my 20 ft report: *http://www.tvfool.com/?option=com_wr...8d173c0ddbe4b6
My current antenna height is just shy of 9 ft (over the soffet but less than the roof peak). And yes pointed at that shed. Here is my 8 ft report: **http://www.tvfool.com/?option=com_wr...8d172c0e4762d6
Thanks for the wiring tip. So I can assume they can be run together?
What about the splitter, sealant, and tripod questions?
@towerguy--thanks. I'm sorry I didn't listen to you. I was only trying to get a consensus. It's hard to tell who knows what on the Internet. I figured if everyone gave similar antenna suggestions then it would be good to go. As far as the original tv fool report height; see my reply to gum above.
I'm willing to try/spend whatever. However, since I already have the RCA ant751 I would like to try to make that work. If elevation and then a preamplifier won't do it, then I'll buy the bigger antenna.
dsmguy7 is offline   Reply With Quote
