Tv Antennas and Reception
The antenna will be connected with/to a non amplified 4 way splitter. DO NOT have the Active cable Tv/cable internet and the antenna connected on the same coax cables at the same time. The coax that provides the cable tv/internet signal to the house must be disconnected at the house. For the internet connection you will need to run a separate coax.
