Tv Antennas and Reception
Only use known to be good coax and splitters and connectors from the antenna to the Tv's. Do not have multipul splits in the coax and antenna system. Each time a split takes place the signal strength is reduced. For 2 Tv's at your location the set up will be like this , antenna , known to be good coax , known to be good 2 way splitter , known to be good coax connected to one output of the known to be good 2 way splitter and coax connected to the Tv , and the other output of the know to be good 2 way splitter is connected to known to be good coax that is connected to the converter box.
