Old 18-Apr-2011, 9:30 PM   #47
Tower Guy
Originally Posted by olimazi View Post
how do I determine what the adjacent channel is that may be causing my reception problem and how do I correct this issue?
WNYW, channel 44 is adjacent to WNJU on channel 43. WNJU is 35 db stronger than WNYW.
Possible fixes are a slight re-aiming of your antenna.
Consider an antenna with a greater front to side ratio.
A notch filter on channel 43.
The use of a pair of antennas configured to null channel 43. (roughly 30" for 109 degrees off-axis)
Some TV sets may be more prone to adjacent channel problems than others.
