Old 18-Apr-2011, 1:23 AM   #45
olimazi
Ch 44
Thanks, it's ch 44 that's getting drop outs - weak 0-35% signal fluctuating.
I'm gonna get on the roof and re-aim the antenna - originally was supposed to aim right at a tree, but i shifted it a few degrees so it's not directly at the tree - since i visualize the signal wrapping around the tree-i grab it on it's way around.
Fox in NYC is available as channel 5.1 in HD on UHF 44. It is also available in SD as 5.2 on UHF channel 38. Similarly, channel 9's programming is also available as sub-channels but on the opposite frequencies. If you're getting 9.1 and 5.2 but not 5.1 and 9.2, then you're missing the signal carried on channel 44.
I'm also concerned that when the maple tree fills in i will have more issues (attached pic). Haven't tucked the downled into the siding yet
Your new antenna is a very large one with a significant wind load. Don't be afraid to install guy wires, if needed to prevent it from coming down and damaging your eave in the process.
olimazi is offline   Reply With Quote
