Old 17-Apr-2011, 4:06 PM   #3
mrpep
Attached is a tip sheet I wrote a while back that applies you your project. It may be helpful.
Your TVfool suggests that you have ample signal power available for your desired distribution system and that you won't need any amplification. I your case, I'd suggest a 2-way and a 4-way splitter connected as follows, providing your cabling runs permit it: Install the 4-way splitter on your down-lead. Take one of the outputs and feed it into a 2-way splitter. Select the three longest runs and hook them to the remaining three outlets and the two shortest runs to the output of the 2-way.
If you'd like to select splitters that is available almost anywhere, I've tested the "Ideal" brand available at Home Depot and Lowes and have found them to be quite good.
Do select a mounting location that permits the greatest avoidance of trees, buildings, and any other obstructions in your line-of-sight towards the Willis (Sears) Tower. Temporarily mount the antenna in any spot and test reception before drilling any holes in the outside of your home's roof or gables.
I will be placing it on the roof later today and will update the thread.
mrpep is offline   Reply With Quote
