Thread: Antenna Newbie
Old 17-Apr-2011, 2:16 AM   #32
dsmguy7
Originally Posted by No static at all View Post
Did you ever try powering just 1 set off of the antenna with the splitter removed? This would provide an excellent baseline to determine how much difference an amp will make.
No, I have not. I will try that. What exactly should I be looking for? I would expect the signal level to double. Is this where the signal strength vs. signal quality on the Tivax STB-12 would come in? Also, should I rescan or just see how the levels change?
Thanks.
dsmguy7 is offline   Reply With Quote
