Old 13-Mar-2010, 9:29 PM   #2
Antenna location
As all Tv and antenna forums say all across the internet , attic antenna installation can reduce signal level by 50% or more. The best way is to actually try the attic installation, if the reception is Ok with you , then it is Ok. The one advantage is the antenna will last a long time. The disadvantage is may be missing some channels if this is the only Tv antenna.
