@mtownsend--Thank you.
@Towerguy--10-4. Thank you. I'm going to see if I can pay my neighbor to cut that tree down or back some. If so, would you do the roof mount to get maximum height or not? If not I'll either do it your way or like your way but with the mast going all the way to the ground to make it easier to run a ground wire to the house ground.
@sobamaflyer--10-4. Thank you. I'll have to check again but I believe WALA is a relatively low powered station even though it is closer than some of the others. This may be why. I may try an amp but I want to exhaust all other means first.
Anyone else care to answer my questions or give an opinion (Groundurmast etc.)?
