Old 15-Apr-2011, 4:17 AM   #19
mrpep
A non-amplified set of rabbit ears will work.
The HD7964P and HBU-33 are both excellent, premium solution options.
An RCA ANT-751 is plenty of antenna.
The C5 is also an excellent product, but not a UHF design. With the signal levels at your location, it would likely work, but is not the best choice.
The first two suggestions, can recover enough signal to insure excellent signal levels after splitting the signal to as many as eight sets. The RCA can drive at least four. .
Regardless of antenna choice, aim at about 110° per your compass.
Looks like NSAA and I are thinking similar thoughts.
110 is east according to the compass on my phone which is perfect and easy. I wont need a mast I can just strap it to my chimney.Should I just aim at the sears tower? Thats where the antennas are and I can see it clearly so aiming is easy
mrpep is offline   Reply With Quote
