Old 15-Apr-2011, 3:42 AM   #18
mrpep
The CM-4228HD is a deep fringe UHF only antenna. It's relatively sensitive to aiming.
Is there a reason you choose to dismiss the advise you solicited?
If you're stuck with the antenna, it will likely offer a long list of programing choices. You could have spent less money and got more though. Antennacraft offers the HBU33 for $57.95 on their website. The HBU22 is $37.99. An RCA ANT-121 is $12.99 at Amazon.
hang on, both the hbu22 and the hbu33 start at channel 7 and up just like the cm-4228hd! These are virtually the same. Check the facts , the only thing that may not be good is the directional aspect. Does it have to be right on like a dish? Or is in that direction good enough?
mrpep is offline   Reply With Quote
