Tv Antennas and Reception
You are doing great. Walking around looking for hot spots is the way to do it. Receiving under the trees leaves often works. It can also help to tip and tilt the antenna. Usually raising the front of the antenna up so the antenna 'looks' at the horizon helps. And believe it or not sometimes having the antenna very close to the ground , about 1 foot above the ground will provide a stable useable signal. It's known as ground wave reception. Also some reception locations have trees close to the house but beyond that it is some distance before there are big trees that can reduce or block reception. And at those locations the antenna is placed beyond the trees that are close to the house.
