Cable and satellite networks do not use ATSC signal format. If you are set up and running on either type network, your TV tuners need to be adjusted if they have the ability to receive ATSC format.
Again, if your TV's are older, with analog only tuners, you will need a DTV to analog converter for each.
If your sets are newer, equipped with DTV (ATSC) tuners, you need to change the setup menu settings to make them understand what type signal to expect.
