Quote;
"" I never thought when cutting the cable that picking up the OTA channels would be the most difficult part .""
Really, in your location,, it shouldn't be. You have better signals than I do, by far, & my set-up was easy. It makes me believe that you are doing something wrong ,, have bad wiring, splitter, connections,, or too many splitters. As others have stated, that antenna on the ground should bring in plenty of stations,,, IF pointed correctly. Before trying to open it's elements, put a drop of oil on all the movable parts to keep from breaking something. Follow the previous advice.
