Old 14-Apr-2011, 2:04 PM   #14
No static at all
No static at all's Avatar
Originally Posted by mrpep View Post
Because I am close to most broadcasting areas wont an attic antenna suffice? Any recommendations? How about this one?
http://www.amazon.com/Winegard-MS-20...2743249&sr=1-2
An attic antenna may very well work. Because signals reflections that can occur with varying degrees in an attic environment, some stations may pixelate. The only way to know for sure is to try it. Just wanted to make sure you would be able to get the antenna back out of the attic in case reception isn't satisfactory. IMO, the HBU-33 would probably be the best bet since it folds back up easily. The HBU-22 or ANT-751 may work, but might not have enough juice to power additional sets.
The signals levels at my location are even stronger, but an attic antenna didn't work well because of the signal reflections.
