Tv Antennas and Reception
As GUM says the antenna on the ground is a all channel Tv antenna and that is Ok. Unless you have more then 6 Tv's in the house do not use any type or kind of amplifier with the outdoor all channel antenna. If you are getting your internet through Time Warner Do Not use the same coax cable line that the internet is on. If you are getting the internet some other way then it's Ok to use the coax lines.
