I am unsure how to proceed, when I start splitting the antenna to multiple tv's (I would like seven tv's total) I start losing channels. I've only added two tv's on a three way splitter and already I've dropped 10 channels (including subchannels). Would you recommend dropping the clearstream 4 antenna and replacing it with something else?
The next logical step is to remove the preamp and power insertion block. Then, let's see how things perform when the antenna is directly connected to the input of the PCT-MA2-8P. Unused ports should be terminated with 75 ohm F-terminators.
Also, be on the lookout for connections going open. (Loose shield connections or wire not gripped by the F-connector it makes up to.)
