The antenna laying on the ground appears to be an all channel antenna designed for suburban or fringe areas. It's bigger than needed, but will receive plenty of signal. Aim it toward ENE (70° per your compass) and you will see all the major networks.
The amplified antenna was either overloaded by the strong local signals or your tuner has not been setup to receive ATSC (Over the Air Digtal), presuming your tuner has ATSC capability. What is the make and model of your receiver?
