Old 13-Apr-2011, 11:02 PM   #2
The Antennas Direct product line has an excellent reputation.
Without a TV Fool Report, I have no way to know if the ClearStream 4 is appropriate for your needs.
Most folks would not commute to work in a 10 Yd. Dump truck, nor would most folks use a small high-mileage compact car to haul large boulders. The type antenna you choose needs to be based on your conditions which include the signal frequencies and strength available at your location.
Follow the instructions here and here to generate a TV Fool Report. Post the link and we will be able to help you, rather than simply guess.
