Old 13-Mar-2010, 9:35 AM   #5
mtownsend
I concur with Dave. The HD8200U is a good antenna for all channels. It will perform significantly better than the HBU-33.
For a low Noise Figure pre-amp, you can use the Channel Master 7777, Winegard AP-8275, or Antennacraft 10G212.
You'll also need a rotator to point the different directions.
This combination ought to give you the best chance at getting a good signal on the most channels.
