Old 12-Apr-2011, 4:39 PM   #12
Joe2011
Really good Info ...
TV Fool Report:
http://www.tvfool.com/?option=com_wr...8d1785476e0249
Wow ... Thanks everyone. Predictably - when I saw this Forum I said "Damn, I wish I'd seen this before I dove into this overhaul project". I've glanced at the Winegard HD 7694 on-line and will research the Antennacraft, Channelmaster, HBU-22 options as well. I don't know that I need to pick up DC stations as; the networks offer primarily the same content other then local news. I see now that the Baltimore channels 11 & 13 are VHF while the other channels 45, 54 & 2 are UHF.
Winegard offers a Winegard MS2000 Metrostar Omnidirectional Amplified TV Antenna that appears to address the two transmission source challenge, with out needing a rotor and picks up VHF/UHF; or are the antenna choices mentioned more appropriate or suited to the closer & smaller directional range "slice" when pointing toward the Baltimore transmission sources, that I should just eliminate multi-direction or the rotor altogether?
I assume the big fat BWI International airport directly between my location and the Baltimore transmission source is just something I have to live with and no amount of "additional quality" in the antenna components will solve ghosting during peak activity times at the runways? Further, if I understand your collective comments correctly, the Baltimore transmission sources are close enough that I don't need a pre-amp because the amplified signal is amplifying the "noise" from the airport and the signal is already strong enough for those primary channels I want if dialed in that direction? Please comment.
Thanks again ...
Joe
Joe2011 is offline   Reply With Quote
