Could the radiant barrier work in your favor? If you're fortunate, yes. But for most it adds an unpredictable element that usually works against good reception.
Factors such as building construction and vegetation are not included in the signal strength prediction.
It will be interesting to see how stable your reception is over time and through wet weather.
That you are enjoying a good signal is good to hear.
