Tv Antennas and Reception
The cable internet cable and the Tv antenna Can NOT be connected together. The cable internet line will need to be separate. You can use the rest of the coax lines if Not connected to the cable line for the antenna. If need to run an other coax line for the antenna to that location then do that. Do Not connect the cable Tv system and antenna system on to the same coax system at the same time.
