Tv Antennas and Reception
If using an 8 way splitter and the signals are to weak for digital lock on of Tv of the weak channels down around KJLA-DT 49 , then use a 8 way distribution amplifier CM3814. If any output ports are not used on the 8 way splitter or 8 way distribution amplifier be sure and put 75 ohm screw on terminators on the unused ports. The reasons are that it provides better balance of the antenna system and keeps out interference.
