How many Tv's are connected ?? You can use the same coax cable that the cable company uses to get the signal from point A to point B in the house , however Do Not have the Tv antenna and 'active cable Tv' on the same coax at the same time. The cable Tv's coax that supplies signal must be disconnected at the house.
