You have one of the best OTA receiving opportunities in the entire world.
You do not need a preamplifier. A preamplifier will be overloaded by the strong TV and FM signals present at your location. Unless you 'need' access to real CH-6 (which may or may not be on the air) you don't need an all channel antenna. A roof mounted Winegard HD7694P aimed at Mt. Wilson will easily drive a passive 8-way split. If I'm wrong, and there are unexpected losses, an amplifier can be added later. If anything, you need to be ready to install an inexpensive FM trap.
