Old 11-Apr-2011, 5:18 PM   #1
Joe2011
Don't know of a solution for this?
TV Fool Report:
http://www.tvfool.com/?option=com_wr...8d1785476e0249
I've successfully installed a LAVA HD-2805 antenna with directional motor and super low noise signal amplifier built in, on my one story ranch house on a 6 ft steel pole secured to the chimney - total height about 30 feet above ground. Un-interupted 50 foot run of coax cable to the motor controller box about 20 feet below next to the TV and then patched thru an RCA digital converter box to my Sony 2001 era analog TV - Clear 180 degree vista toward the front on the house (12:00 O'Clock) The transmitters for the weakest stations are at 3:00 O'clock. Tall trees behind and on sides of house. A big fat international airport directly between the antenna and "TV Hill" in Baltimore. Channels 11 & 13 weak ... channel 38 same transmitter location - strong?! After 9:00PM - channels 11 & 13 are stronger - though they do not appear to register stonger on the RCA digital converter box signal strength meter?
Is there a way to "amplify" channels 11 & 13 further?
Please advise.
Joe
Joe2011 is offline   Reply With Quote
