Old 11-Apr-2011, 12:15 PM   #5
Dave Loudin
To drive all the TVs in your house, you should mount the antenna outside. Unless there are houses or trees in the way, you need only to be 10 feet off the ground to have a clear shot at the LA stations. You might be able to use the smallish RCA ANT-751, but a larger Winegard HD-7694P or an AntennaCraft HBU-33 will certainly do it.
