Ottawa, ON updates
CRC-DT-1 has been on the air testing intermittently recently. It's the Communications research Centre's experimental ATSC channel. It's been using PSIP 3.1
If you're updating networks as well, here are the networks for Ottawa, ON area stations:
digital:
CBOT-DT 25 (4.1) CBC
CBOFT-DT 22 (9.1) SRC
CRC-DT-2 46 (46.1) experimental
CFMT-DT-2 27 (27.1) OMNI1
CJMT-DT-2 66 (66.1) OMNI2
CRC-DT-1 38 (3.1) experimental
CKXT-DT-3 20 (20.1) SunTV
CRC-DT-3 46 (46.1) experimental
CRC-DT-4 46 (46.1) experimental
CRC-DT-5 46 (46.1) experimental
analog:
CBOT 4 CBC
CJOH-TV 13 CTV
CIII-TV-6 6 GTN
CIVO-TV 30 TQ
CBOFT 9 SRC
CICO-TV-24 24 TVO
CJMT-TV-2 14 OMNI2
CFMT-TV-2 60 OMNI1
CHRO-TV-43 43 A
CITY-TV-3 65 Ind
CHCH-TV-1 11 Ind
CHOT-TV 40 TVA
CITS-TV-1 32 Ind
CFGS-TV 34 V
CKWS-TV-3 36 CBC
CIII-TV-2 2 GTN
CKWS-TV-2 26 CBC
CJOH-TV-8 8 CTV
CHRO-TV 5 A
CKWS-TV 11 CBC
GTN=Global. ISTR that the IC database uses this abbreviation.
for the pending, WNYF-LD plans to have WWNY CBS on 28.1 and Fox-SD on 28.2, so I imagine you could brand this as CBS.
Analog WNYF-LP in Massena is Fox.
