For reception of the Tv stations at 326 magnetic compass I recommend a Winegard HD7698P antenna with a Winegard AP8275 preamp. Antenna height at the location does not help that much , so mount the antenna on the roof at about 20 feet high from ground to antenna. WPSU PBS may come in on the back side of the antenna. If not and you will like to receive it then will need to ad a rotor such as the Channel Master rotor or will need to install a second antenna such as the 91XG. A preamp will not be needed with the 91XG pointed at WPSU for one or two Tv's. If you go with the 2 antenna system then the coax from the 2 separate antennas will not be connected together on to one coax. The 2 antenna systems will be separate. A remote control A/B switch will be used at the Tv or Tv's to switch antennas. If 2 Tv's are connected then use 2 way splitters with each antenna. Remote control A/B antenna switch - AB27RS . Channel Master antenna rotor - 9521A.
