Old 10-Mar-2010, 7:03 PM   #1
RººR
Recommedations please
Hi all,
Looking for some expert advice.
My signal analasys:
http://www.tvfool.com/?option=com_wr...b7c88debcf7926
My house sits in a valley and is surrounded by trees.
I was curious to see if i could receive OTA TV and purchased an Antennacraft HBU33 and a pre-amp/indoor amp from my local RS.
I mounted the antenna/amp approximately 30ft above ground and am using the old RG6 cable from the existing DirectTV dishes.
ive tweaked the antenna direction from anywhere between 79º-92º. I receive all the majors and then some and the strongest station is ABC 7.1 coming in at a max of 70%. All other stations fluctuate between 35% and 50%. I am pleased with the resulsts but I get some dropouts and pixilating and think I could fix it with some better equipment.
My thoughts are either:
1- install a CM4228, CM7777, Winegard YA1713 and a rotor
2- install a Winegard hd8200u and an amp if necessary
or
3- install a Tereves DAT 75, read they are good for weak signal areas due to valleys and trees.
Regardless of what I end up installing I will be upgrading the cables to new Quad Shielded RG6 and new grounding hardware, just want to do it all at the same time.
Thanks in advance!
RººR
RººR is offline   Reply With Quote
