Here is a idea , it is Ok to search tvfool and find answers , It is Ok to to click on Special Topics and Enthusiast's Exchange. It is Ok to to look at the top of the page at tvfool and find the word Search , click on it and type in the grounding. Here is the main reason for grounding the coax cable from the antenna , Grounding the coax with a coax grounding block diverts atmospheric static and signals that will interfer with quality Tv reception - to earth ground. The electric service ground wire is a good place to ground. An other good place to ground to a cold water pipe , the cold water pipe must be real metal pipe that goes down in to ground out to the water main or to a water well. Do Not use a hot water pipe for ground.
