@COCO-Could be buddy. Thanks for the heads up.
@GUM-Thanks man. Your posts are helpful as always. I did what you said and I have my antenna pretty close. I'm still going to get a compass. I really think it is an elevation issue and the fact that the antenna is pointed at an out building and behind that (higher too) is a privacy fence, and behind that are two large oak trees.
1.) Can pictures be posted here?
2.) In keeping the antenna and mast away from power lines; does that include an insulated line going into the house?
3.) Can a roof top 10 ft. mast not be guy wired?
4.) If I do the roof mount how do you run the ground wire (just along the roof and off the eave with a stand off?)?
5.) I have some sort of Comm-scope Tri-shield rg6 (model #: F677TSVV) UL CATV 18 AWG. Is this good?
Reason: Edited to stay on-topic
