For all of the virtual channels you have listed, signal levels are no problem at all. The challenge will be to find a single aim point that offers reliable reception of all five stations.
A fairly compact, reasonably priced antenna like the RCA ANT-751 mounts quite easily and has a broad beam which will give you a good chance of seeing all stations from one aim point. As a starting point, try aiming south. Pan in either direction if you are not able to see all of the signals reliably.
As a last resort, you may need to consider using a rotator. I would try without first.
