Old 10-Mar-2010, 12:03 AM   #6
mtownsend
In general, installing an antenna yourself is not terribly hard to do. It mostly involves "erector set" type skills (working with hand tools) to set up the mount, mast, and antenna. The wiring aspect is also fairly straightforward. If you can hook up your own home entertainment system, then connecting an antenna and pre-amp should be no problem. Granted, some people feel more comfortable around electronics than others, but this is not rocket science, and if you ever have any questions, there are people on this forum ready to help.
