Old 4-Apr-2011, 10:28 PM   #16
mtownsend's original advise is still true. If your rabbit-ears or other indoor antenna is unreliable, you will need to consider at least two options.
1. A two antenna system - An Antennas Direct DB-2 facing 263° per your compass and an RCA ANT-751 pointing toward 135°. Neither antenna should need any amplification, you have plenty of signal available. Each antenna would be cabled to an A/B selector switch at the TV set so that you can connect the appropriate antenna. Each antenna needs to be outdoors with a clear view in the direction indicated.
2. The RCA ANT-751 mounted on a rotator in a location with a view in the directions cited in option one.
