Old 4-Apr-2011, 11:27 AM   #21
Dave Loudin
Depends on what you mean by unplug. If you simply mean unplug the power cord, then that is extremely bad advice. In most, if not all cases, the un-powered preamp passes almost NO signal, so it is worse than having no preamp at all.
Please remember that you are in a signal-poor area, and what has worked for you is not generally applicable.
