Old 4-Apr-2011, 4:53 AM   #2
PBS and a religious broadcaster will be fairly easy to receive. After that you will need to use the largest available antenna. Two competitors, Antennas Direct XG91 and Winegard HD9032. If you can not safely mount so as to put the antenna above the nearby foliage and obstructions, I expect you will see some but not all of the major networks reliably.
You would also need a high quality preamp such as the Antennas Direct CPA19 and a rotator. The Channel Master CM-9521 is a consumer grade option, the Hy-Gain AR-40 is a more substantial piece of equipment as it's price suggests.
