Old 9-Mar-2010, 5:57 PM   #10
mtownsend
The DB2 is a fine UHF-only antenna.
WTVI is on channel 11, so you may or may not get it depending on how much luck you have picking up a very strong VHF channel through this UHF antenna. All your other channels are on UHF, so they should be fine.
The DB2 does not come with a stand, so you'll need to rig something if you plan to mount this inside somewhere.
